Best oil for 454 mag mpi in Arizona heat!!
I never quite understood why boats don't just use a straight 50 weight oil and be done with it. The 20 in the 20W-50 is for winter weight...i don't know of anyone running their boats in cold weather! I mean iv'e boated in low 60's in the early Fall but that's about it. I always used a straight 50 weight oil in my boats
-Wally
-Wally
IMO
j272 (05-28-2022)
Heh, Do people with stroker motors use stroker oil ?
underpsi68 (05-27-2022)
what exactly does ambient air temperature have to do with anything? Your oil temp whilst operating will be the same whether it is 10 degrees outside or 110 degrees...?
But for God's sake never use Puke-oil...er, Penzoil if you want ANY sort of engine life!
Baja 252 Islander
Baja 252 Islander
what wrong with penzoil?
prob be ok if its 100*F. out.
you don't live in Arizona we boat all year boat never rests here!! even in winter we dont go below 60....
In Arizona the difference when water temp is 90 degrees, so when your engine is cooled by lake water, definitely makes difference. Compare to 89 outside and lake water is 68. You bet it makes a difference when you live in a state where your Max temp is 88゚ in the summer. Or here when it's 115 out and lake water is 90+ , but what do I know , ask my wife not ****!
If you're running the proper thermostat and your cooling system is operating properly. What difference does the ambient temperature and oil have to do with anything?
