496HO Down on power >
496HO Down on power
496HO Down on power
Old 08-03-2022, 07:56 PM
  #141
Originally Posted by SB
Water can clean’m too. I see this slot on various engines, usually ones with some cam and marginal exhaust for them.
SB,
Referring to reversion? This is a bone stock engine, aside from the ECM tune and ProCharger. As far as I know, this is the same cam that Merc built it with. It’s also the stock 4” exhaust, too. It would seem strange that only two cylinders would do this, though.
My nephew, who works for me, and has done his fair share of fiddling with engines, has suggested this could be a valve train issue, ie wiped lobe on the cam. Possibility? I know. This is starting to sound like a zebra hunt.
Thanks. Brad.
(937)545-8991
Brad Christy is online now
Old 08-03-2022, 10:08 PM
  #142
SB
Received 3,117 Likes on 1,403 Posts
Not saying you have that issue. Just letting people know that can keep plugs looking new (unfired ) also. Have seen it lots of times. Perfectly running engines, go to change plugs or look at’m to make sure all okay, and they look new even after a season huh.
SB is offline
Old 08-03-2022, 10:20 PM
  #143
SB,
I would think that, under ideal conditions, that would be the case for ALL spark plugs. That said…
The Merc 496 is well known for running rich. Hence the legendary “transom soot” they are so well known for. I am assuming that is what we are seeing on six of the eight plugs out of my engine. But TWO of them are squeaky clean. The question is WHY.
I seriously appreciate everyone that has contributed to the solving of this puzzle.
Thanks. Brad.
(937?545-8991
Old 08-03-2022, 11:49 PM
  #144
Received 1,824 Likes on 909 Posts
Griff,
Do they steam? 😁
This is something that “new”. When we did the sea trial, I can remember laying my hand on the risers and they were barely lukewarm, at most.
like I said, I’m not super worried about it. But I AM going to keep an eye on it and look into what might be going on.
Thanks. Brad.
(937)545-8991
Depending on lake water temp and ambient temps and humidity, I will get some steam from one side sometimes and both at cooler ambient temps.
Guys,
How reputable is Kunkle’s marine? Anybody have any dealings with them?
I just got off the phone with them, seeking an appt to meet up at the lake (Alum Creek in Central Oh) and run the boat on a scanner. He told me a scan is all but useless, and that I was likely looking at more of a mechanical issue, rather than an ignition or fuel delivery issue. He mentioned head gaskets. I’m not hitting the panic button, but his advice being directly counter to what I see as overwhelming consensus here on OSO has me wondering.
Thoughts?
That is really jumping the gun on his part. The first thing any decent marine tech is going do in your case is scan the engine.
The exhaust manifold temp sensors, I believe, will set off an alarm and throw a code....and put the engine into guardian mode.
Griff is offline
Old 08-04-2022, 05:45 AM
  #145
Griff,
Steam….. Noted.
Kunkel….. Agreed. When I said they had me “wondering”, it was about them, not about the OSO consensus. While he said a couple things I think I agree with, I’d be much more inclined to go with what most of you guys say rather than what one shop looking to boost sales is saying.
Temp sensors…. I don’t believe they getting near hot enough to worry about at this point. My main concern is if something is developing, like an impeller going sideways, or a blockage coagulating, that might leave us stranded 30mi up the South Fork at Cumberland one of these days.
Thanks. Brad.
(937)545-8991
Old 08-04-2022, 06:44 AM
  #146
SB
Guys,
Plugs out. Same as last findings. #4 and #7 showing no signs of combustion. Squeaky clean. MAYBE a hint of a smell of gas on these two. Kind of hard to be sure.
Since #5 was of interest previously, I took some closeups of it, as well. I’m not sure what was going on with it last time, but it looks pretty much identical to the others this time around, excepting #4 and #7, of course.
Thoughts?
Next, I plan on swapping the injectors. Ill swap them the same I did the coil packs; 4-6 and 7-5. I’ll take pictures of them as I do so. I’ll also figure out a way of getting some video of the spark tester in use, under load, on the water.
Repeat…. Anybody have any actual dealings with Kunkel’s?
My hips and shoulders are going to mount a protest before long….. 🙄
Thanks. Brad.
(937)545-8991
When you pull the injectors, look at the little basket screen/filters in top of’m. If filled with debris, remove screens and clean, then reinstall.
SB is offline
Old 08-04-2022, 06:47 AM
  #147
SB,
Noted. Will do.
Thanks. Brad.
(937)545-8991
Old 08-04-2022, 08:07 AM
  #148
To the best of my knowledge the 8.1 has hydraulic roller lifters. It's not impossible but highly unlikely the cam is getting wiped out, that's usually a flat tappet issue/problem. The tell is glitter in the oil, valve train noise and material in the oil filter .
carnutsx2 is offline
Knot 4 Me (08-04-2022)
Old 08-04-2022, 08:13 AM
  #149
Carnuts,
We are getting none of that, that I can tell.
For the record, I am not expecting to find valve train damage to be the problem. I am now thinking it's injector related. We'll be getting to validating or ruling that out soon enough.
I had a very informative phone conversation with Smitty this morning. He gave me some tests to perform before we start disassembling. Tip o' the hat....
Thanks. Brad.
(937)545-8991
SB (08-04-2022)
Old 08-04-2022, 07:45 PM
  #150
Guys,
OK.... So, I just did a bad thing.
You know what they say about every ten-minute job is just one broken bolt away from a three-day ordeal...?
In the process of getting the starboard side fuel rail back into place, I needed just a tiny bit more clearance behind the coolant reservoir. I gave it just a t-i-n-y little tug, heard a snap, and coolant started draining into the bilge. Farq.......
After an hour of trying to figure out how to get the bracket loose that seems to hold it in place, I got frustrated and yanked it the rest of the way out. Yup. Just as I thought. The snout that the coolant hose connects to cracked right at its base. It's toast. Now that it's out, though, I don't think it will be a huge ordeal getting a new one back in.
Looking around, they all seem to be special order or "out of stock". Just wondering if anybody has one lying around...? New. Used. Don't care. liquid tight is good enough for me. I'll pay.....
Thanks. Brad.
(937)545-8991
