How to determine what exhaust I need?
So it sounds like through transom exhaust with a dam prevent water from getting back inside. I am a bit confused though, because it is an I/O it has to be water cooled, the water is sucked up to cool the motor and dumped into the exhaust to drain…..or so I thought??
so how is the water cycled then? I assumed it was dumped in the exhaust?? If this was a sports car I’d know where to go, haven’t been into boating for very long…and the boating season where I live lasts for about 3.5 months is all.
With dry marine exhaust, the water doesn't go from the cooling jacket of the exhaust, into the exhaust gas stream and out the tailpipe.
The water is dumped overboard via a separate hose that is usually plumbed from the cooling jacket, to a through hull fitting.
There's many variation also as to where water can get introduced if it does so to speak in a dry exhaust.
