Bad leakdown test results - 502 MPI >
Old 07-26-2022 | 01:59 PM
TomZ's Avatar
I'd try some Seafoam or trans fluid dumped into the intake tract to see if you can get rid of the buildup.
If you can pull the valve covers and rockers, you can try staking the offending exhaust valves to try knocking away debris. A deadblow hammer would get the force there without damaging the tip. A block of wood could also be used. It's crude but can help with sealing.
I'd exercise those options before tearing it apart (especially with those iron ship anchor heads).
TomZ is offline
Old 07-26-2022 | 02:20 PM
Veteran: Army
I'll do it at dusk so at least I'm keeping the mosquito population in check :-D
DrFeelgood is offline
Old 07-26-2022 | 02:26 PM
TomZ's Avatar
TomZ is offline
Old 07-26-2022 | 03:04 PM
I have four of them I have been moving around all day Thinking about adding a "per pound" surcharge on Iron heads
BillK is offline
Old 07-26-2022 | 03:23 PM
TomZ's Avatar
I just took two pairs to the machine shop to be looked and thought I was going drop testicle trying to get them into the truck. It was also 98 degrees and 80 percent humidity but still.
TomZ is offline
Old 07-26-2022 | 05:17 PM
SB
Wait till you pick up aftermarket bbc cast iron heads. Make oe cast iron bbc feel like small block heads. :wink
SB is online now
Old 07-26-2022 | 06:17 PM
My guy will only work on Iron BB heads for good friends. And only if an emergency. He complains the whole time whe he's doing it.
1983ScarabIII is offline
Old 07-26-2022 | 07:13 PM
The only thing worse is the Ford 6.0 / 6.4 diesels. They are 85 lbs each I actually weighed one a while back after doing a pair.
I have gotten so spoiled with the aluminum heads that almost everything has on them now days. I can pick up an LS head in each hand and move them around.
BillK is offline
