Bad ignition module symptoms?? >
Old 07-26-2022 | 09:40 AM
bigboat28's Avatar
Default Bad ignition module symptoms??
What are the symptoms of a bad ignition module in a 500efi?
Anyone know the correct part number? Was looking on line and there appear to be a few different ones. It would be going on whippled 500efis.
bigboat28 is offline
Old 07-27-2022 | 12:21 AM
The pick up module in the distributor??? Most of the time, they just quit or will quit when they get hot
Griff is offline
Old 07-27-2022 | 04:43 AM
SB
Current Merc part#:
https://www.mercruiserparts.com/merc...08208-module-d
I believe (but don’t quote me) the AcDelco is this:
https://www.amazon.com/gp/aw/d/B000BYGD7E https://www.amazon.com/gp/aw/d/B000BYGD7E
Remove old grease from pad module is mounted tooUse thermal paste, not the improper dielectric grease that comes with them. Put on extremely thin.
SB is offline
Old 07-27-2022 | 08:00 AM
miss fires on this system are most often the pick up coil and where it connects to modual they corrode and lose contact put a goooood new pick up in around 25 bucks
boostbros is offline
Old 07-27-2022 | 11:05 AM
Mine would make a miss and not get above 3000 RPM's when it got hot.
Topshelf38 is offline
