High oil temp >
High oil temp
High oil temp
Old 08-25-2022 | 04:48 PM
Default High oil temp
Just put the stage two Whipples on my merc 525s and oil temperature is running up to 220. Cannot figure out what’s causing it.
please help
aharley62 is offline
Old 08-25-2022 | 04:51 PM
220 I dont think is considered high.. I added oil thermostats so my oil would run 220*. Anything less and I don't think you will burn off any condensation.
bigfarmer is offline
Old 08-25-2022 | 04:52 PM
F-2 Speedy's Avatar
where were they before
F-2 Speedy is offline
Old 08-25-2022 | 05:02 PM
SB
This ^ as 220f in of itself is perfectly fine for an oil temp.
SB is offline
Old 08-25-2022 | 05:49 PM
jeff32's Avatar
My 500 temps are between 200-225
for what it is worth
jeff32 is offline
Old 08-25-2022 | 06:40 PM
Veteran: Army
Oil temps go up with load / rpm. 220F at idle would be high. 220F under sustained load is fine.
DrFeelgood is offline
Old 08-25-2022 | 06:44 PM
SB
Originally Posted by aharley62
190
30*f not bad for 200+hp increase. HP is heat. And again 220*f for max oil temp is tony the tiger grrrrrreeeeeeaaaaat.
SB is offline
Old 08-25-2022 | 06:45 PM
190
Old 08-25-2022 | 07:16 PM
F-2 Speedy's Avatar
190
I run 190-95 on a long pull 25-27 miles @ 70-75 with stock coolers but Im not running closed cooling, running Whipple water pump delete no stat and 2 stage pump
