Melting pistons - but only 7 & 8 Fuel???
Throttle setting ? help me here! what do you mean?
What if your correct with above and my AFR is high and i have slightly less fuel getting to those rear pistons with the higher AFR (14) would that maybe cause just the rear pistons to be leaner and not cooling the same as others? hence the melting????
articfriends (08-30-2022)
The following 2 users liked this post by articfriends:
SB (08-30-2022), sutphen 30 (08-30-2022)
Smitty, I was the one that said sometimes too little info is as bad as too much info. it was not a dig at you or all the great info you post, I have learned a lot with what you put out there. it was more that with too much info sometimes people get lost in it all and wind up overlooking simple things. please keep up the great work.
Back to the thread...
to add to what Smitty said on throttle position. on the open class race boat with Stirling engines we found that in smooth water with a long straight run you had to pull the throttle back to about 50% to keep it off the rev limiter. this was a 46 Skater so as it aired out it got lighter and rpm went up so at the end of the straight you were at 7800 rpm at 163 mph and half throttle. hard to map for that on a dyno or even in the water. we had to look at a lot of data logging and create a map on the computer to allow for it.
The following 4 users liked this post by compedgemarine:
Hey everybody, thanks for all the input and will let you know my outcome...
Thanks Smitty for your time, i had an EFI tech guy look over my engines and he believes its all about the fuel pumps, he said fuel pumps are not good enough to pull out the top of the tank (2 foot High) thru a filter and then push the fuel back up into engine.
Im going to fit surge tanks and use a lift pump from main fuel tank to pre pump filter 100-150 mic - to surge tank -then fuel pump -then filter 75-100 Mic - then up into fuel rail - out to Regulator - return back to surge tank, and then from surge up and back to fuel tank.
Hopefully got this correct... Oh and add a shut off valve.
If your pump is mounted even or lower than the tank bottom, once the pump is primed its no longer really "lifting" the fuel. I know nothing about the pumps you have. But if it was fuel pump you'd have melted parts of all the pistons. Your issue is the fuel map. On fresh engines that weren't dyno tuned you need to keep it 12.5:1 and work leaner from there. Letting it get to 14:1 without testing is asking for trouble.
articfriends (09-03-2022)
