Cam lobe wear - 502 MPI >
Old 09-04-2022 | 06:58 PM
Veteran: Army
Originally Posted by AllDodge
What's the difference between the Merc 502 MPI cam and another manufacture?
Looks like several sell cams for the 502
The issue is ECM reprogramming. There's nobody local that I could have tune my ECM after a cam change, so I'm basically limited to stock or *really* close to stock at this point.
DrFeelgood is offline
Old 09-04-2022 | 07:33 PM
ok, thought the Merc 502 was just the GM crate motor 502
AllDodge is offline
Old 09-04-2022 | 07:45 PM
Veteran: Army
Sadly the cams are different. The stock 502 MPI cam is a Gm part but it's NLA.
Old 09-04-2022 | 07:54 PM
Good to know, I have the cam that came out of my 502 MPI, but it began its life as a GM crate motor
AllDodge is offline
Old 09-04-2022 | 08:59 PM
SB
See if it has a part# or something in nose of the cam.
SB is offline
Old 09-04-2022 | 09:10 PM
-how fast do you need a cam?I have 502 mpi's sitting in my garage.I'm changing cams so these will be available.just need to know how fast you need it.
Bill
sutphen 30 is online now
Old 09-04-2022 | 10:30 PM
The camshaft in the picture looks like a grey cast iron camshaft that would use flat tappets. I thought that the regualr production factory roller camshafts for Gen VI were all produced with steel material not cast iron.
Long Stroke is offline
Old 09-05-2022 | 01:16 AM
TomZ's Avatar
1622 0094 is the laser etched identifier on Gen VI MPI cam that I just sent out (1998 502 MPI).
The GM part number 12551622.
GM 502 435 hp cam.
Interesting… Merc rates at 415. To bring an old argument up, is that at the prop? Seems that 20 hp loss through the drive would align with that.
I looked online real quick for the cam. Nada. Will more than likely need to come from someone’s bin.
TomZ is offline
Old 09-05-2022 | 04:13 AM
Veteran: Army
GM 502 435 hp cam.
Supposedly, the HP discrepancy is that the black motors were rated at the prop. Blue motors rated at the crank.
And yeah, the GM part no is basically gone online. A few mentions in some forums from 10+ years ago.
Old 09-05-2022 | 04:16 AM
Veteran: Army
Bill
Well, I'm not trying to get back on the water by next weekend or anything... I'm hoping to find a cam sometime this month. If nothing turns up obviously I might readjust the plan. Thanks!
