Bam 1350 gone bad >
Bam 1350 gone bad
Bam 1350 gone bad
Old 09-13-2022 | 11:54 AM
Originally Posted by Diamond Dave
I had one of my 1500's blow a front seal out a few weeks ago out of nowhere. It was just sitting on the shaft when I took the trans out it dumped all the fluid into my bilge. I feel your pain lol
I heard there was some kind of a fix for the front seals blowing out. Valako was mentioning it but wasn’t real certain.
getrdunn is offline
Old 09-13-2022 | 12:06 PM
Originally Posted by TomZ
Actually, my issue was at the pump up front caused by the drive plate ejecting springs and screwing the alignment.
Seems to me it's probably the transmission and not the drive. I'd get the drive off to see what it feels like disengaged from the trans. Maybe an issue in the tailstock?
Does that seem possible? I guess if it was completely grenaded and tore up inside I could see the prop shaft rotating hard???
getrdunn is offline
Old 09-13-2022 | 01:13 PM
TomZ's Avatar
That side had a clicking and vibration. When I got it apart, all of the springs were gone and the plate was cracked. I assumed that it came apart because of that (seemed reasonable). May have been the pump seal issue mentioned earlier. it dumped fluid in it faster than you could put it in.
TomZ is offline
Old 09-15-2022 | 03:20 PM
Tom you were right. I pulled the drive back today and spins as free as can be. As hard as that to turn over and time even couldn’t I would’ve never thought the tranny would do that. I just don’t normally get lucky like that. Now I have to ask myself do I pull that engine and tranny and use one of my fresh stock rebuilds for another weekend or possible two of running or do I say screw it. If it was earlier in the week I’d likely do it. Realistically it would take me about 8 sober hours but still a lot of work for what little time is left up here.
getrdunn is offline
Old 09-15-2022 | 03:49 PM
TomZ's Avatar
I’d put your good backup in it and go boating. Your rebuild should hold up. That’s what I’d do.
TomZ is offline
