Mercury 409 MPI >
Mercury 409 MPI
Mercury 409 MPI
Old 10-17-2022 | 06:53 PM
Originally Posted by underpsi68
How much torque does it make since it is being compared to the 8.1?
it lust 650 at 3600 rpm
AllDodge is offline
Old 10-17-2022 | 07:04 PM
The new 409?
underpsi68 is offline
Old 10-17-2022 | 07:06 PM
Is this a GM small block or the Merc produced piece that replaced it sometime around 2015?
JaayTeee is offline
Old 10-17-2022 | 07:23 PM
I am sure this is an all in house Mercury block, etc. so that when you have an issue you get to buy parts from Merc for 10 times the cost of normal sbc parts.
compedgemarine is offline
Old 10-17-2022 | 07:25 PM
Veteran: Army
I think pretty much all of Merc's current offerings are in-house, likely for that exact reason.
DrFeelgood is offline
Old 10-17-2022 | 08:36 PM
SB
Says needs gears changed in outdrive, therefore not near as much.
would be cool if they mention cubic inch and other particulars. Just mosrky marketing ‘hype ‘ terms at this point.
Not that it matters i guess because way too much money for the end result.
Really seems they hate inboards and i/o’s and wanna just churn out outboards. IMHO
SB is offline
Old 10-17-2022 | 08:47 PM
F-2 Speedy's Avatar
Pretty sure I could build 2 650 hp BBC for the asking price......
F-2 Speedy is offline
Old 10-18-2022 | 10:27 AM
My guess is it is the MERC produced. Link below says 4.035" bore and 4" stroke. So sort of usual Gen 1 small block combination.
Which the new 2015 up MERC 6.2 seems to be a near identical copy of.
409 Spec Sheet
The new 409?
He had to mean the LT4.
I didn't find any dyno charts or torque specs on the new Quicksilver 409.
Because if the 409 makes 650 lb-ft at 3600??
We definitely need to see that.
Originally Posted by techman
I also noticed that the Quicksilver 8.1 and the 540 Mag stroker are no longer available. Looks like this is your Mercury sourced replacement for big blocks with a warranty.
In Quicksilver yes.
Mercury still has the 8.2L/502 in³.
Uncertain if they'll sell those for repower or not?
cheech is offline
Old 10-18-2022 | 10:47 AM
Is it any cheaper for flat plane crank engine to be built by mercury or others?
PA.WOODCHUCK is offline
Originally Posted by Mbam
Performance 400 horsepower 5000-5800 RPM Exotic idle quality Great acceleration Flat-plane crankshaft 150# lighter than 8.1L Speed gains with Bravo One X
Technology ECM 555 SmartCraft 10-pin harness Engine Guardian MPI fuel injection Mechanical throttle & shift
Black-X valves Dry joint iron exhaust Heavy-Duty iron block Forged crank, pistons & rods Shaft-mounted roller valvetrain Full System Fresh Water Cooling Heavy-Duty Eng. oil & PS fluid coolers
Single-point water drain 3-year limited warranty 25W-50 engine oil Long-life coolant Remote oil filter 87 octane fuel
985 pounds. List price $33,425, available next month.
Can you sell just crank? Or the whole bottom end? Price?
hogie roll is offline
