PSI 8.8 liter / 550ci ???
#141
An example adding to perspective.
A 454 with Peanut Port heads (70s-80s) that are mildly ported out, will make 570HP at around 5600rpm with 2.19 valves. Reliably.
With low...just over 8:1 CR...and a FT hyd cam.
Popular Hotrodding Mag in 2001..had an article on a 350 SBC ZZ4 Short Block...with 195cc AFR Heads. All off the sheld parts build. Made 520HP at 6600rpm.
PP heads have about a 208CC port...avg 13more CCs than the SBC port...but the BBC port longer...and it really comes down to port CSA. It's a high velocity port when drawn with 454 cubes and some rpm....but they can flow a lot of air.
#142
#143
The PSI engines are def an interesting project.
Ported PSI:
[email protected]
[email protected]
Def going to have some potential.
