Mercury ITS and Gimbal Ring replacement >
Old 11-18-2022 | 08:43 AM
fandango's Avatar
From: Solomons Island, MD, Vero Beach and Punta Gorda, FL
Default Mercury ITS and Gimbal Ring replacement
Looking for procedures for replacing gimbal ring on ITS. I am assuming motor has to come out, but do you have to remove entire assembly to get to top of pinion nut?? Any help appreciated.
Thanks in advance.
Ed
fandango is offline
Old 11-18-2022 | 09:08 AM
You have to split the box from the transom assembly to access the upper swivel pin.
Unlimited jd is offline
Old 11-18-2022 | 09:45 AM
fandango's Avatar
Unlimited thanks! Do you have to remove the transom assembly to be able to split case or can you get to it while assembly is still on boat??
Thanks in advance.
Ed
fandango is offline
Old 11-18-2022 | 02:14 PM
If the engine is setup as a driveline installation you can reach in and get to the hardware, not easy but possible. If the engine is bolted to the transom plate it has to come out
