Head bolts 454 MPI >
Head bolts 454 MPI
Head bolts 454 MPI
Old 12-07-2022 | 05:19 PM
SB
All dodge, the arp’s dr feelgood linked are for mark iv- gen vi bbc’s with oe cadt iron heads.
see here.
https://www.summitracing.com/parts/A...1/applications
The lengths may slightly different than ie bolts because arp’s come with thick hardened washers. OE doesn’t.
SB is offline
Old 12-07-2022 | 05:23 PM
SB
Also. All dodge, 4.380 headgasket totally fine on a 4.310 bore and stock head.
SB is offline
Old 12-08-2022 | 08:29 AM
Thanks much
I didn't get notified of the posting, but this kind of thing happens all the time these days
Will look for the 4.380 gasket. Was doing the compression ratio calculator (summitt) and must be entering something wrong because its coming up with 8.1
Bore 4.31
Stroke 4.0
Cyl head vol 118cc
Piston vol -2 (using standard pistons)
Deck .018 (std deck .018 to .020)
Gasket .039
AllDodge is offline
Old 01-01-2023 | 06:48 AM
This motor does not want to be built
Installed heads and tightened bolts down in 4 passes. FelPro said wait 10 minutes and loosen each bolt one at at time and retighten to spec in one pass. Never done this before but ok since FelPro stated.
Well one of the block threads said NO and heard a crack and it wasn't from the torque wrench. Removed the bolt and piece if thread on the bolt. bolt is fine but not the block. So we have a Helicoil ordered and another head gasket.
AllDodge is offline
Old 01-01-2023 | 07:04 AM
you can reuse the head gasket,no need to replace it just because it was torqued down.
mike tkach is offline
Old 01-01-2023 | 07:15 AM
Veteran: Army
Yup, should only need to replace if heat cycled.
DrFeelgood is offline
Old 01-01-2023 | 08:29 AM
ok, will advise, but $50
The motor goes in a 37 foot cruiser inboard which has to hire a semi to haul out
AllDodge is offline
Old 01-01-2023 | 06:16 PM
What are you torquing them to ?
BillK is offline
Old 01-01-2023 | 08:42 PM
SB
Canadian Torque.
Tighten it till it breaks, then back off a hair.
SB is offline
Old 01-02-2023 | 06:16 AM
89 on long and 92 on short
Still not getting notified of postings
AllDodge is offline
