Head bolts 454 MPI >
Head bolts 454 MPI
Head bolts 454 MPI
Old 01-02-2023 | 07:53 AM
SB
Originally Posted by AllDodge
89 on long and 92 on short
Still not getting notified of postings
Whose bolts ?
I don’t remember torque values this high, but been a few yrs for me on a 454.
SB is offline
Old 01-02-2023 | 08:15 AM
ARP and torque is 92 long and 89 short
AllDodge is offline
Old 01-02-2023 | 08:40 AM
SB
That looks like Mercruiser Manual, no ?
Torque values and procedures to use are those of the head bolt or stud manufacturer.
SB is offline
Old 01-02-2023 | 09:22 AM
Merc yes, APR states torque in passes to 70 then final torque is per OEM
AllDodge is offline
Old 01-02-2023 | 09:29 AM
SB
No.
Just the sequence is OEM.
Torque value is from the bolt and lube used.
SB is offline
Old 01-02-2023 | 09:32 AM
The statement from ARP is one which puzzles me some. ARP states the bolts are stronger then OEM but they use OEM spec for final torque. Torque should stretch the bolt so it maintains the clamping load. If their stronger then the same torque would not stretch the bolt the same and provide the same clamping load, or at least IMO
AllDodge is offline
Old 01-02-2023 | 09:37 AM
SB
Originally Posted by DrFeelgood
I just used ARP for my Gen VI 502 MPIs.
ARP-135-3601
Here are the directions for those bolts.
https://tech.arp-bolts.com/instructions/135-3601.pdf
SB is offline
Old 01-02-2023 | 10:15 AM
89/92lbs is a lot on a 7/16 bolt/stud.
1/2" are usually 100lbs.
underpsi68 is offline
Old 01-02-2023 | 10:28 AM
135-3601.pdf
Your right both instructions are the same, we over torqued.
I should have read the paper instead of listening to what my friend said it was saying. So its over torqued.
Will loosen each one at a time and torque to 70
Wonder if it crushes the gasket to much?
AllDodge is offline
