Cooling system upgrade questions >
Old 01-09-2023 | 07:48 AM
Originally Posted by BBYSTWY
Thanks for the advice! I think I will be ok with the increased volume as I never see anything on my pressure gauges unless I'm moving and I have dumps on the back of the intake with no stat or circ pump just wide open. Would it benefit me at all to run a say -4 an into the chiller to get some kind of flow through it for long idle periods or just leave it alone? Thanks again!!
wouldn't hurt anything to tee a -4 off of your bell housing cooler to the chiller..
bigfarmer is offline
Old 01-09-2023 | 08:01 AM
BBYSTWY's Avatar
Considering that would essentially tie the 2 independent systems together, the dual sea water pump engine cooling side and the no pump intercooler side, should I put some kind of check valve in the -4 tee so I don't get bleed back from the cooler circuit or do you think pump pressure will always exceed non pump pressure through the cooler? Just don't want to cause any interference issues. Thanks bud!
BBYSTWY is offline
