Bravo XR
There is no difference besides ratio. Any bravo x or XR can go behind a gas engine. They all work and perform the same no matter the stickers or coating on the outside.
The “diesel” drives are typically a higher ratio. So if you need a 1.5 ratio any x or xr 1.5 will work
If it's got the replaceable plastic hub, yep ^^^^^, just get the 1.25 shaft hub.
