Sending unit questions >
Old 03-30-2023 | 01:20 PM
SB
Hex heads i use the head of a hex bolt just use 2 nuts on its threads to lockem so you can turn the bolt.
If allens, and the strip, alot of times a torx bit will takem out.
SB is offline
Old 03-30-2023 | 03:02 PM
F-2 Speedy's Avatar
you can tap a 12 point socket on a hex head and break it loose, had to do it on stock Merc head bolt
F-2 Speedy is offline
Old 04-07-2023 | 10:51 AM
Thanks for the tip. It worked perfectly. Thanks again.
PQ290Enticer is offline
