Roller rocker wear >
Roller rocker wear
Roller rocker wear
Old 04-21-2023 | 02:11 PM
F-2 Speedy's Avatar
And you think the milky substance is due to just sitting ? or is there another issue.
F-2 Speedy is offline
Old 04-21-2023 | 02:22 PM
I think it's just from sitting over the winter - not too concern with that. I just fired it up for the first time this spring, so I could take another look but my assumption is that oiling is good.
I guess to hone in on my question. I'm questioning if the shop that did the rebuild actually put new rockers on. The wear after 4-5 hours seems excessive and sort of like they looked before. They had issues getting the Comp ones and told me they were going to put Crane ones on. I opened it up and sure enough it's the same Comp ones I had beore. However, maybe the found a set of Comp rollers. The wear marks is what's making me question it and I paid for new rockers.
540Fever is offline
Old 04-21-2023 | 02:27 PM
Is this still the build from the guy that wouldn't respond to your questions or is this the 2nd builder? How many hours were on your engine before the rebuild? In other words, maybe the question is, do these "new" rockers look like they have several hundred hours on them?
PQ290Enticer is offline
Old 04-21-2023 | 02:30 PM
F-2 Speedy's Avatar
Sounds like they told you a story, if you paid for new Crane ones and they aren't on the engine they owe you what they billed you for, Im sure they never thought you'd open it up
Old 04-21-2023 | 02:31 PM
Wrong guy. I only had one shop build it.
Yes, that is the question I just asked. Would you expect this wear out of 4 hours run time?
540Fever is offline
Old 04-21-2023 | 02:33 PM
F-2 Speedy's Avatar
Not really unless there is an oiling issue, is there milky on the dip stick
Old 04-21-2023 | 02:34 PM
Yeah that’s my concern. I don’t care if they’re Comp or Crane if they’re new. They look like they have some hours in them to me.
540Fever is offline
Old 04-21-2023 | 02:37 PM
Just pulled it looks good, fresh oil from when I changed it last fall.
540Fever is offline
Old 04-21-2023 | 02:38 PM
GPM
Doesn't look like you're getting a lot of oil to the rockers. Maybe there was some debris left in the block
GPM is offline
Old 04-21-2023 | 02:43 PM
I just wiped them off. I’ll pull another cover after just firing it to see bit I don’t think it’s an oiling issue. I think it’s an old parts issue.
540Fever is offline
