Roller rocker wear >
Roller rocker wear
Roller rocker wear
Old 04-21-2023 | 12:29 PM
Default Roller rocker wear
I’ve got about 4-5 hours of run time on the new motor. Would you expect to see wear marks on the roller tips this soon? They all have wear mainly on the outside edge of the roller.
540Fever is offline
Old 04-21-2023 | 12:50 PM
GPM
What brand are they ?
GPM is offline
Old 04-21-2023 | 12:59 PM
Comp Cams Pro Magnum
540Fever is offline
Old 04-21-2023 | 01:03 PM
by
by https://www.flickr.com/photos/32474676@N02/, on Flickr" target="_blank">
" target="_blank">
540Fever is offline
Old 04-21-2023 | 01:06 PM
They're supposed to be new rockers, but I'm not so certain which is why I ask. They were the same ones I had in the motor originally.
540Fever is offline
Old 04-21-2023 | 01:20 PM
GPM
Why does everything look dry
GPM is offline
Old 04-21-2023 | 01:23 PM
GPM
It could be my eyes, but I'm used to seeing everything soaked in oil after running.
GPM is offline
Old 04-21-2023 | 01:24 PM
It was a little milky condensation from sitting so I wiped them off.
540Fever is offline
Old 04-21-2023 | 01:50 PM
F-2 Speedy's Avatar
bingo, looks the same to me
EDIT: what kind of oil pressure are you seeing ?
F-2 Speedy is offline
Old 04-21-2023 | 02:06 PM
I wiped the rockers off because they had milky condensation on them. Oil pressure is good 60+ at idle
540Fever is offline
