Electric raw water pump idea..
Would have to be a pretty serious electric water pump. The belt driven bravo pumps move a serious amt of water. If the bravo location is kickibg your azz and if If you have room, think about going crank mounted. Several semi recent threads on this.
For...why? What purpose? Other than a MINISCULE reduction on parasitic drag for the ICE, what possible advantage could there be, and at what cost in complexity of the system?
Baja 252 Islander
Baja 252 Islander
My turbine boats that had water cooled exhaust all had electric water pumps. They flowed a ton of water but were also pretty heavy. In my mind an engine mounted pump on a gas engine is a lot simpler.
