Gen 6 502 vs Gen 7 8.2L 430hp are the blocks compatible?
So my machine shop is killing me hardcore, I dropped my engine November 11th 2022 for a rebuild said he would be all over it in January so its ready for spring. Well he ordered parts for it and never surveyed the block and here we are April 27th and he calls me today to tell me its cracked in a water jacket (its a new anchor)!!!!!
I found a guy selling a Gen 7 (never knew there was a Gen 7) its a new mercury 8.2L that one cylinder got nicked and it needs a small overbore which is fine sinve I have .030 overbore pistons for my Gen 6 block. My question is are they compatible?
[QUOTE=Joeyboost;4865847]So my machine shop is killing me hardcore, I dropped my engine November 11th 2022 for a rebuild said he would be all over it in January so its ready for spring. Well he ordered parts for it and never surveyed the block and here we are April 27th and he calls me today to tell me its cracked in a water jacket (its a new anchor)!!!!!
I found a guy selling a Gen 7 (never knew there was a Gen 7) its a new mercury 8.2L that one cylinder got nicked and it needs a small overbore which is fine sinve I have .030 overbore pistons for my Gen 6 block. My question is are they compatible?[/QUOT
I havent been in one BUT on bill mitchell website they advertise a aftermarket Gen 7 and it says " 8.1 l head bolt pattern" with SAE threads so Id hold a head gasket on it or a head before buying it
Will his Gen 7 block be compatible with Gen 6 internals? I have a set of .030 JE pistons in the box for my block that is now junk. I would need to use my rods and crank in this block.
cracked where? if it is to the outside they can weld it as it only holds water pressure. if it is a cylinder can it be sleeved? if it is to the lifter valley side then scrap it but I have seen plenty of blocks fixed
Gen 7 would of been an GM 8100 or 496 in the MerCruiser world.
I can't tell what the 3rd to last digit is.
Seen this casting number at the site below.
19165955...454...............1996-2001 L29
502 casting numbers from the site.
10237300...502.......96-up...4-bolt, Gen.VI, 4.466" bore
12561358...502...............4-bolt, Gen. VI
14096859...502...............4-bolt, Gen.V, HO
Chevy Casting Numbers (enginerepairshop.com)
