New flywheel or no? >
New flywheel or no?
New flywheel or no?
Old 04-30-2023 | 04:18 PM
Default New flywheel or no?
After reading through this thread, am I understanding that I can just re-use my old GenV 454 flywheel for my new build 454 bored over to 496 and stroked?
flywheel
I did buy an upgraded harmonic balancer. no way I’d use the old one on a motor making double the power.
Batmeat is offline
Old 04-30-2023 | 06:10 PM
Rookie's Avatar
You should have had the flywheel and new balancer with it when the engine was balanced. Internal or external balance with the new rotating assembly?
Rookie is offline
Old 04-30-2023 | 06:35 PM
it’s already internally balanced. Forged internals. Didn’t come with a flywheel or harmonic dampener
Batmeat is offline
Old 04-30-2023 | 09:34 PM
SB
Therefore, you’re flywheel and dampener need to be for neutral balance.
Did you have these ‘kit’ parts checked for measurements and balance ?
SB is offline
Old 04-30-2023 | 09:47 PM
you need a new flywheel that doesn't have the extra weight added to it.its in the form of a large casting bump out from the outer edge.
sutphen 30 is offline
Old 04-30-2023 | 11:25 PM
good to know and yes I did. 👍🏼
Batmeat is offline
Old 05-01-2023 | 07:20 AM
You can have your flywheel neutral balanced. Any machine shop that does crankshaft balancing should be able to do it for you.
Which damper did you buy ? It needs to be internal balance also.
BillK is offline
Old 05-01-2023 | 08:37 AM
I have chucked them in a brake lathe and removed the weight and then just had the final balance done with the rotating assy.
snapmorgan is offline
Old 05-01-2023 | 10:01 AM
this one
however, I’m considering on sending it back and going with ATI
both are internally balanced and SFI spec 18-1
Batmeat is offline
Old 05-01-2023 | 10:42 AM
Originally Posted by Batmeat
this one
I would go with the ATI for sure. One thing with the ATI damper. They almost always need the hub to be honed to get the proper interference fit. They are almost always too tight. If you order it directly from ATI and you have a way to precisely measure your crankshaft snout, they will hone it to the correct fit. Otherwise most good machine shops should be able to do it for you although a lot of guys do not have the correct mandrel for the rod hone to do the job.
BillK is offline
