2015 Mercruiser 8.2 - High RPM Issues
Update - Put everything back to stock. Hoping that I had separate issues.
1. The fuel system was causing the drop in RPM. - Fixed after the cats were removed.
2. Removing the CATs and adding that aftermarket bypass caused the codes.
3. When putting the CATs back in I found that one of the manifold temp sensors was not connected and the other had a broken wire.
Testing tonight.
Testing tonight.
At this point you need to buy the scan tool (you really should have one if you're going to own a computer controlled marine engine).
https://www.rinda.com/rindashop/?sfi...tic-converters
