Pressurizing stat oil cooler >
Old 05-24-2023 | 10:16 AM
Default Pressurizing stat oil cooler
Easiest way to pressurize a stat oil cooler (and) with or w/o stat in place.
One is still plumbed in boat and other is on shop floor but plumbed on engine.
Had some oil in both blocks last fall shake down run. Both coolers new but process of elimination.
tks
getrdunn is offline
Old 05-26-2023 | 05:42 AM
Ayuh,..... Pressurize it from both directions, 'n look for bubbles on the water side,.....
Bondo is offline
Old 05-26-2023 | 09:16 AM
Wally's Avatar
Were doomed!
i would get some air line fittings and hook them up on the oil side of cooler and pressurize it up to what your highest oil psi readings you get....then dunk the coolers into some hot water...like near boiling, to try and simulate the oil temps as much as possible and let it sit there and watch for bubbles...if there's a hairline crack it wont show up until there's some heat in there to expand it all...
Not sure about on the motor....i would just take them off to be sure.
-Wally
Wally is offline
Old 05-28-2023 | 10:44 AM
I kinda thought the same and just use bathtub to ck. The cooler with PS is like 27” plus. I’d have to agree with simulating conditions best.
Pressure gauge on one end and small gate valve on other.
getrdunn is offline
Old 05-29-2023 | 08:47 AM
Menards stocks these. Plug one end of cooler with a pipe plug. Insert the tester into other end. Charge with 30psi.let it sit overnight.
https://www.menards.com/main/plumbin...261-c-8523.htm
MILD THUNDER is offline
Old 05-29-2023 | 09:28 AM
Tks joe - Hope all is well. with or without stat in place? H
getrdunn is offline
