Oil temp gauge not working
I saw on a different thread that you shouldn't use any tape or sealer on this sending unit because it could keep it from making a ground contact. I of course saw that after mine was installed. I also used the sealer where the fitting goes into the oil filter block and the other end is a rubber hose so in this scenario it was never going to work???
I read many sources on this issue. My professional engine builder used teflon tape. My understanding is that between the leading threads (without tape) and the high points of the threads cutting the tape...it seals and grounds/makes contact.
Smart👍 I'm terrible with plumbing and so i coated top to bottom
I have never had a problem using teflon sealer on pipe threads on sending units. The way that pipe threads work they seal on the threads and there will always be some metal to metal contact. Is the part that it is screwed into grounded ? Takes 10 seconds with an ohmeter to see. It looks like it should be grounded through the bracket to the manifold.
if you weren’t going to do the ohm test, I would start by checking (and replacing if necessary) the ring terminals on both ends as well as the ground and power supply to the gauge. As suggested check the ground wire (bonding wire between assemblies on engine this varies by setup).
The gauge itself probably has 3-4 connections, Power, ground, data, lights optional. At least mine does. I doubt you have an individual fuse anywhere. But make sure the gauge has power…I saw that once. All senders and junk worked on but no power to gauge, buddy was fit to be tied it was fixed in 5 mins.
Senders do go bad and are relatively cheap to replace. checking for continuity on wire would be my next step after that. Followed by a whole lot of some stress relief. Just break the circuit down and go piece by piece. Whatever you choose not to test is normally the thing that is broken
