Volvo penta leaking water from motor >
Old 07-23-2023 | 10:50 PM
Default Volvo penta leaking water from motor
There’s a fitting in left side of motor by spark plugs that leaks water when running does it need to be plugged or no ? First Volvo penta please and thank you
Zach32scott is offline
Old 07-23-2023 | 11:28 PM
What engine???
If its below the spark plugs then its probably the engine block drain.
Is this a new to you boat?? Have you used it yet??
Griff is offline
Old 07-26-2023 | 08:34 PM
A "Volvo Penta" is the outdrive. The motor is something else
f_inscreenname is offline
Old 07-27-2023 | 12:40 AM
Volvo Penta has been making marine engines for 50+ years. Most recent and current offerings are GM based and very similar to Mercruiser.
Griff is offline
Old 07-28-2023 | 12:23 PM
If it's a Chevy motor, it's a Chevy motor. In the past the only difference was maybe a cam profile and most of them were just truck cams. 😊😊
Old 07-29-2023 | 12:19 PM
The first answer is yes it needs to be plugged no boat should have water dripping inside. Check for freezer plug or manifold drain could be split hose get a mirror and flashlight and see wre it tis coming from
boomer is offline
Old 07-30-2023 | 06:31 AM
Ayuh,..... This Op has a thread at iboats, with a picture,...... It's his exhaust manifold, that freeze busted,......
Bondo is offline
