Nose cone removal >
Nose cone removal
Nose cone removal
Old 08-22-2023 | 03:43 PM
  #31
35fountain's Avatar
Originally Posted by Tartilla
With some heat on the allen plugs, you may get a few out by the threads. Otherwise drill them out.
...no wonder you never got anywhere with little drill bit by hand.
Great progress so far.
Thanks My First Time LOL...As for the tube in the front. cut it flush. then crimp it and seal it?
35fountain is offline
Old 08-22-2023 | 05:45 PM
  #32
Before doing anything with the tube...I would open up the original water inlets. There are some good threads on the newer style and hole size/placement.
That way you can use the tube to flush out any metal filings etc from your work.
Large front tube...if it was me, I would likely clean it up the aluminum and weld it back up using a piece to cover the hole.
Without the equipment and costs, and not seeing it first hand. It's difficult to suggest a solution. Assuming the tube is aluminum? Or something like that?
Trying to get enough material (epoxy style JB Weld) in behind the opening to resist the hydro forces may block the water inlet flow in the hollow passage.
Tartilla is offline
Old 08-22-2023 | 05:54 PM
  #33
35fountain's Avatar
I believe it is aluminum. I will have to do crimp it cut it down and use marine tex. I will mold it contour with that part of the drive.I do not have anything to weld aluminum.
Old 08-22-2023 | 06:10 PM
  #34
35fountain's Avatar
Can you explain this? Trying to get enough material (epoxy style JB Weld) in behind the opening to resist the hydro forces may block the water inlet flow in the hollow passage.[/QUOTE]
I will not be using that water port anymore.. I will being opening all the holes on the sides of the drive where the original water inlets were.
Old 08-22-2023 | 06:30 PM
  #35
I will not be using that water port anymore.. I will being opening all the holes on the sides of the drive where the original water inlets were.[/QUOTE]
How far in does the tube go before it opens up into the water gallery? (The water passage inside the drive that feeds the impeller.)
Trying to plug the pipe after cuttting it flush at the taper, you may get some JB weld or whater you use out of the pipe inside and block the water flow from the newly opened water inlet. For that matter, the pipe itself may be a flow obstruction.
Tartilla is offline
Old 08-22-2023 | 06:43 PM
  #36
35fountain's Avatar
Trying to plug the pipe after cuttting it flush at the taper, you may get some JB weld or whater you use out of the pipe inside and block the water flow from the newly opened water inlet. For that matter, the pipe itself may be a flow obstruction.[/QUOTE]
I have no idea how far that tube goes in. Its sticks out about an inch. How big is the water passage in the drive. Should I remove the pipe completely? then what? How do I seal up the drive. I should have left the nose cone on. Lesson learned again.. Anyone have a bare case. The other nose cone is staying on for now.
Old 08-22-2023 | 07:23 PM
  #37
35fountain's Avatar
Heres an idea. Lets put it back on. What do you recommend to use
metal to metal ?? Filler
or?
Old 08-22-2023 | 08:23 PM
  #38
I appreciate you want a solution that keeps you on the water until you can focus on it with some breathing room.
​​​​​ne
You need to have something to keep the filler in the tube from getting pushed in.
The inside of the tube could be dremel'd up in circles inside, creating a locking ring.
If you cut down the tube on the angle, and cut it a bit deeper than the drove angled surface, the JB weld would have something to hold on to outside the tube. It would also feather out once sanded.
Is the vertical gallery in front of the main shaft for the water? The 8 side holes would line up with that.
Hard to find cutaway photos of the Bravo 1.
Tartilla is offline
Old 08-22-2023 | 08:45 PM
  #39
I ran an SEI lower for a couple seasons with about 600 HP. Ended up losing the upper and lower still looked great at tear down.
im MartinB is offline
Old 08-23-2023 | 05:24 AM
  #40
35fountain's Avatar
​​​​​ne
the easiest way out is to clean up the nose cone and put it back on for now. Before I do that maybe I should remove the brass plugs first. I unscrewed one plug and there was water in there.Then hook a water hose to my engine flushes and see how much water comes out of the sides of the drives. I can also temporarily cap the pipe with a rubber cap for testing only.
Another idea. I open all holes up and the cut the nose cone where the pipe goes into. Have a shop weld the other side of the piece cut and use this as a cap for the drive.This way the hydro forces cannot push anything back in.
I could also plug the tube with some kind of threaded pipe plug them marine tex it or flare out the pipe if it's aluminum so it grabs onto the drive. This will hold it in place.
