Alternate cam for a ZZ502? >
Old 08-14-2023 | 05:43 PM
Steve H's Avatar
artselectricinc.com
be careful on changing parts plunger depth need to stay the same so you dont get into changing puss rods also
Right now the plan is to use the GM lifters that came with the short block, most likely requiring new pushrods.
Steve H is offline
Old 08-14-2023 | 05:46 PM
Steve H's Avatar
artselectricinc.com
This cam seems to have the right duration and lift, except it is 112 LSA. Old cam is 114.
https://www.summitracing.com/parts/c...8#applications
Steve H is offline
Old 08-14-2023 | 09:32 PM
500efi and 525efi cam clones. For your boat, I'd prob go with the 500efi cam which is essentially a Crane 731 on a 114
Teague Custom Marine | BBC Gen V-VI Billet Camshaft - Stage 1
Teague Custom Marine | BBC Gen V-VI Billet Camshaft - Stage 2
Griff is offline
Old 08-15-2023 | 02:27 PM
Steve H's Avatar
artselectricinc.com
Thanks Griff
Are these cams compatible with GM lifters that came with new engine?
The lift is slightly more than the MK cam, will they require stiff springs?
Thanks!
Steve H is offline
Old 08-15-2023 | 02:29 PM
F-2 Speedy's Avatar
Are your current cams std firing order ?
F-2 Speedy is offline
Old 08-15-2023 | 03:18 PM
Steve H's Avatar
artselectricinc.com
No, they are not.
Steve H is offline
Old 08-15-2023 | 03:19 PM
Steve H's Avatar
artselectricinc.com
No, they have two holes swapped. I don't remember which ones.
Steve H is offline
Old 08-15-2023 | 03:48 PM
Steve H's Avatar
artselectricinc.com
The cam and springs below seem to be what to be what I need. Teague said they have both in stock, and can ship
same or next day, which is a major plus. Springs were suggested by them, and they didn't see a problem
with the stock lifters being used.
https://teaguecustommarine.com/comp-cam-springs-bbc-500efi
https://teaguecustommarine.com/bbc-gen-vi-billet-camshaft-stage-500efi
Steve H is offline
Old 08-15-2023 | 06:23 PM
Can’t you re-use the cam from old engine that matches the heads and valve train that your moving to the new block? Would match your other engine as is…?
Powerquest230 is offline
Old 08-15-2023 | 09:47 PM
Crower cams might have something you are looking for. 221/230 @.050 on a 114 LSA in a SBC and no reversion. Something along that line should work.
Trash is offline
