camshaft pressure bleed off vs. compression ratio >
Old 12-02-2002 | 06:52 PM
Travis,
Here is the phone number for Erson Cams. 800-641-7920. Ask for Steve Tanzi and he will help you pick the right cam for your application. Solid rollers give a wider power band and generally a flatter torque curve as opposed to hydraulic rollers. This plays well especially in a light boat. You can run a looser prop that really pulls hard in the mid range, and still have a great top end because you can just let her sing. 6000 plus RPM is no problem on a SBC. My dads 355 has 7 seasons with a solid roller and no problems. This motor turns 6000 RPM natural and 6500 on the nitrous. We don't change props, we just let her sing more R's with no prob. I think this winter we are going to pull his motor for a refresh and to try to find some more speed. There are a lot of people afraid of solid rollers because of some of the horror stories told on OSO. Most of those are told by big block guys.
Good luck!!
Craig
WETTE VETTE is offline
Old 12-02-2002 | 06:55 PM
Biggus's Avatar
Back about 20 yrs ago, I was into Mini Coopers and David Visard tought me how to build a 130 hp BMC 4cyl.
Traviss, great thread man!!!!
Biggus is offline
Old 12-02-2002 | 08:01 PM
traviss's Avatar
Thanks wette vette, i'll drop him a line when I get time
My roller lifters are held straight in the bore by a retainer that holds guide plates over the lifter bores, so who makes a solid rolller that works with this GM lifter guide setup. I am not for running rollers with connecting bars, buddies at GM have tested them and it was never a good turnout..
traviss is offline
bcarpman
2
09-03-2006 08:59 PM
danielthelen
5
05-09-2005 02:44 PM
danielthelen
1
02-20-2005 07:57 AM
seahawk
2
05-24-2004 12:21 PM
KAAMA
13
10-02-2002 10:09 PM
