Upgrades
Old 08-27-2023 | 11:41 PM
Default Upgrades
Hey all appreciate any input on some future upgrades - not getting to call out a specific season for these upgrade because I’m focused on the remaining bit of summer.
Had motor and drive rebuilt summer of 22’ so first full season with it. Did some tuning, props, and seat time which made a big improvement. Started at 73 and darn near touched 80 back in June, 79.7. It’s got 80 in it just don’t have a lot of opportunities to run it wide open in good water.
540 with Dart 310’s, CMI’s, Dart intake, and a 1050 Pro Systems. B1 with XR 1.50’s, 28p B1, IMCO lower standard -0. Made 640 tq @4700 620 hp @5700. Currently turn the boat to 5450 with this prop which is about 7-8 hp from peak.
Heads were just redone with valve job, springs valve’s etc. Initial thought was to sell these and get a set of AFR CNC w a cam swap. The raised intake ports make me nervous going from a .300 to .375. I doubt anything is going to line up. Alternatively, spoke w a head guy about working my Darts, doing 2.30 valves, port work, swapping to a Vic Jr intake and a new cam. That would be the easiest from a plug and play perspective. Probably not a huge $ consideration between new heads or working my heads but the raised exhaust hasn’t something I want to deal with. Has anyone swapped similar raised exhaust ports? Is it a pain or can it work?
Last piece is considering a new lower IMCO SC -2. This is on a 27 Fountain and seems others have had good success. My X is 18.5”. Assuming the boat likes a shorter drive, what kind of mph can be picked up?
No real goal in mind but would like to pickup 5/6 mph in a realistic world.
540Fever is offline
Old 08-28-2023 | 06:36 AM
TomZ's Avatar
Sounds like she’s running real good - 5-6 mph is another 100 hp. Not sure I’d mess with it.
TomZ is offline
Old 08-28-2023 | 07:44 AM
Tom - you sound like my wife 😂 Appreciate your response, and you’re correct, it’s running good for what it is.
Maybe the juice isn’t worth the squeeze on this effort.
540Fever is offline
Old 08-28-2023 | 09:20 AM
TomZ's Avatar
Don't tell mine! She'll have a field day with that comment!
TomZ is offline
Old 08-29-2023 | 02:46 PM
articfriends's Avatar
The AFR heads are nicer then the dart 310s, not 6 mph nicer though. The fact your Engine made more tq then hp, however teslls me your cam kinda on the small side or quite advanced or both. What are your cam specs, do you have the short CMIs with captains call where reversion is a concern?
articfriends is offline
Old 08-29-2023 | 05:59 PM
I was given a couple different cam spec's although both sort of close..
114 cl, 109intake / 119 exhaust 622/646 lift
I also received another cam spec from them, so not sure which one is accurate.
241/253 @50 615/630
We're not on great terms, so unless I pulled the cam and somehow measure it i'll probably never know.
540Fever is offline
Old 08-29-2023 | 09:03 PM
I "upgraded" from Skip white heads to Brodix. Spent close to an hour on the phone with them to make sure I would get the best heads to maximize gains. All said and done I maybe gained 1 or 2 MPH and that's with twins. And really the water pump delete probably helped that.... They do sound a lot different in a cool way though... but dunno if it was worth almost 10k time it was all said and done.
im MartinB is offline
Old 08-29-2023 | 10:36 PM
Dont ****ing touch it , go boating.
NEXT!!!!
Old 08-30-2023 | 07:19 AM
Fine... I'll put down some SeaDek this winter and call it a day. Thought you guys encouraged others to make bad decisions as well
540Fever is offline
Old 08-30-2023 | 08:50 AM
BBYSTWY's Avatar
My vote is a cam swap and whipple it....then you don't have to worry about how the heads flow....however I have not had my boat consistently running more than a few weeks over the last few years so I guess I'm the bad advice committee hahahaha
As others have said...I would leave it unless you're doing something drastic like adding a blower. You can honestly probably play with labbing props and get a couple more MPH and be cheaper than more engine mods on a perfectly good running engine
Just my opinions lol
BBYSTWY is offline
