Lifter making noise
#61
Those lifters are junk. I would not replace just one set and have to worry about when the next set fails and takes out the entire engine.
Whats more expensive, set of lifters and pushrods or an engine rebuild?
That being said he has no idea what`s wrong so who knows what it is.. just a guessing game at this point
#62
#63
I'll bet a dollar it is a stuck plunger. had that happen on at least one of several sets of comp lifters which is why I refuse to use them. the last one was a flat tappet motor with about an hour of run time. I pulled the lifter and was able to get it apart and polished the bore and the edge of the plunger and it is still working but I have limited faith in the rest of them.
#64
Last time I used a set of comps was shortly after graduating high school so been a while.
Anyone know who makes them for comp this day and age?
When my builds were in the dream stage the lifter subject was on roids so I went solid and never looked back. Really glad I did and just ck lash once a season! The solids in a couple of my muscle cars rarely need an adjustment when I ck those about every other year now.
#65
The cost of machining a block to accept .904 lifters isn`t bad . The lfiters a bit more expensive but they are quite a bit beefier than a .842, thats the route I went .
https://www.yellowbullet.com/threads...fters.1809794/
my old comp craps on the left ,Morels on the right.
so far so good.
so far so good.
Im just here for the lifter discussion, were upgrading a friends boat this winter and dont want to go the wrong way.
#66
Lifter issues (IF thats even what you got going on) have became a real big deal in past 10-15 years. Heres my experience/opinion on it: I used Morel lifters (hyd rollers) when they became a "thing" back in 05/06, running 180/195 seat and close to 500 lbs open up to 6300 in my own blower engine WITH 20/W 50 oil. Never had a tick or issue. Retired them at every refresh interval at about 100 hours. Also used them in quite a few customers builds with no issues regardless of oil weight. Fast forward, no matter what lies CHRIS S####B, JOHN C#####S perpetuate, around 2014 they changed something. They sped up production, sent lifter bodies to Mexico or China, IDK BUT they started having failures , plungers failing/sticking. tie bars breaking, roller wheels disintegrating. CHRIS SXXXXB in conversation on FB made THIS statement: They ONLY have 1 pair of lifters out of a 1000 sets that fail, thats funny because I flow/clean injectors for several other engine builder/dyno guys in this business and EVERY SINGLE ONE OF THEM HAS HAD FAILURES and will never buy Morels again. The comps are a step below, seen guys have failures on street engines before 5000 miles with them.
As far as hyd flat tappets, the ONLY engines I build with them anymore are class rule engines that dictate you run them (which is rare for me), and I wont warranty them in any way, shape or form. I put it in writing that any failure is customers problem and make them sign it as cam core/lifter construction has went right in the trash..Ive used johnson lifters successfully in last 40 or 50 mild bbcs ive built with no isuues.
I had one customer who i used the Morels with from that 2014/2015 era, in 2019/2020 Bob M who had sold them to me asked if customer had any issues with them. I said NO except they were noisy cold. He highly recommended changing them before they failed. I mentioned this to the customer who said nah, Im selling boat soon anyways, not worried about it. a couple rides later one failed and destroyed his cam, lifter bore etc and trashed his whole engine. Was around 150 hours IF I remember correctly
#67
Then again, everywhere takes longer to get there in it
#68
Mystery has been solved. Got the intake off and it looks like the plunger is stuck. Push rod looked fine. Cam lobe looked fine too. I am going to order a replacement set and button this up.
Thanks for your help.
