CP Performance 1/2 system closed loop cooing kit >
Old 10-04-2023 | 04:58 PM
  #31
Steve H's Avatar
artselectricinc.com
Originally Posted by Joeyboost
Mounting the system down in the stringers didn't create bleeding issues? I have a vacuum bleeding system that works awesome on my 2003 Cobra because that car is an air pocket nightmare when doing anything with the cooling system. I assume it will work the same on a closed loop in the boat.
Coolant reservoir is mounted on top of engine. I don't recall ever having an issue purging system of air.
Steve H is offline
Old 10-04-2023 | 05:01 PM
  #32
Steve H's Avatar
artselectricinc.com
Originally Posted by Tartilla
More work from draining the coolant?
I was thinking of setting up a pumped system to draw the coolant out and store it while engines are out. Unless it needs changing of course...but at least something that is simple, and avoids the bilge mess.
Probably a Tee and a ball valve to a guick connecter.
More work to remove engines, because of the extra hoses between engine and heat exchangers.
Steve H is offline
Old 10-04-2023 | 07:48 PM
  #33
scippy's Avatar
That one line in that photo to the pump doesn't look to healthy is that what let go? If not might want to replace that before it does.
No, it was the line running atop the strb. stringer to the power steering filter.......thinking of getting rid of the old automotive ps pump & reservoir tank would be a good idea ...something like
seafordguy has ........if you look at his picture his hydl. line to the pump looks like it's on it's way out!
scippy is offline
Old 10-05-2023 | 06:04 PM
  #34
seafordguy's Avatar
Yes - it’s looked like that for years. Luckily it’s a braided line so I’ll pray it lasts another couple seasons……
seafordguy is offline
