Oil cooler / power steering cooler
87 - my oil coolers are actually mounted under the front of the motors and I have a small separate PS cooler that’s just an inline cooler from the raw water. Not sure if you can see my coolers in this picture once it loads. I could take a picture this afterNoon if you’d like….
my oil coolers are pretty small and over a 20 mile run I’ll see 240* water temps, but that doesn’t bother me with Mobil1. Frankly I like to get it up that high on occasion.
I haven't gotten around to getting my setup out and listed yet....It will be available as soon as I get the motor pulled and get it all off. The holidays and a bunch of OT at work have sucked up all my time lately ugghh
I've come to the conclusion that simple connectors for elec and coolant (fresh water exchanger) with easy drains for IOT re-use, is the way to go for me.
I don't want to see pulling engines as a 'drag'.
Seems an aluminum reservoir tank is sufficient for cooling. Add air cooling fins if required.
