BBC 0.700" wheel, hyd roller lobes.
For an undervalved engine like the BBC, bigger valve is mostly better for sure.
I think the Flotek seats were cut so you could use a 2.25", as the seat area was quite a ways into the valve face. So your're getting the 2.3" valve shrouding without the best port opening width. But that may have just been those heads...or they've changed their process etc.
Bore notch the block.
0.340" lobe is still only 0.578" lift with 1.7 rockers. Throw 1.75 or 1.8's if you want more lift. What do the heads flow at 0.600"+
That single pattern cam looks like a cam my engine builder has. Where was it located?
