Adjustable push rod guides >
Old 03-06-2024 | 11:37 AM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Originally Posted by PQ290Enticer
I am someone that really needs and benefits from the knowledge base on this site and I hope you will continue to help me as I go along.
Thanks again for all the help with this........situation.
The exact reason I came to OSO all those years ago and stayed. Up to that point, Knowledge gained was in direct proportion to parts ruined. A boat is NOT a car! lol
the deep is offline
Old 03-06-2024 | 11:53 AM
Not a lost cause, you just learned something and did it yourself.
Should be a point of pride.
Wildman_grafix is offline
Old 03-06-2024 | 05:44 PM
Talking
Originally Posted by Griff
Why wouldn't a professional engine builder already know this and why didn't he realize that the rocker alignment was significantly off and correct it???
Better watch he`ll call you crazy and ask why you`re so angry all the time with that attitude!!!
Keep that microagression at bay please
ICDEDPPL is offline
Old 03-06-2024 | 08:51 PM
Good questions Griff. ( I was hoping that this thread would just die out )
Everyone on here knows that I am not an engine builder and FYI, I don't understand a lot of the "tech talk" here whether its engines, props, or whatever. Unfortunately for my boat, I do like to do as much of the work myself as possible. Whether I should or not is another question. Anyway, I like to think that I am learning ........and then this happens.
I pulled the valve covers on the first engine and low and behold, it already has the adjustable guide plates. The exact adjustable guide plates that I just bought again from AFR. ("AFR Racing Pushrod Guide plates 6109-8")
I don't know why the alignment was off on many of them. It's a larger shop and he has a guy that does the assembly. I do think the alignment should have been better. Maybe even though the alignment wasn't perfect, they would have gone 1,000 hrs anyways? My understanding is the higher the rpm, the more critical this is? By todays standards my engines are pretty low key and not high rpm mills. Anyway, I went through the first engine and have them all decently centered now.
I realize that it's sh!t like this that makes me look like a lost cause but believe me, I am someone that really needs and benefits from the knowledge base on this site and I hope you will continue to help me as I go along.
The fact one engine had them and the other didn't baffles me even more about your engine builder. Unfortunately you trusted somebody who you thought knew what he was doing, and in many ways he did not.
Never have I thought you were a lost cause. I prob had no more knowledge than you when I joined OSO 25 years ago. I had basic hot rod car mechanical knowledge. 90% of the details about marine stuff, I learned here and there still a ton of stuff I defer to people with a lot more knowledge than me.
Griff is offline
Old 03-07-2024 | 03:49 AM
I think this engine builder needs a name. I see lots of west Michigan people on here and think it would be fair to know if it saves us in the future...
Ryanw10 is offline
Old 03-07-2024 | 08:43 AM
jbraun2828's Avatar
I asked the same thing last year. I had some questions about his builder before his boat even hit the water. I'm glad he made it through the season though.
jbraun2828 is offline
Old 03-07-2024 | 11:44 AM
SB
Wonder what would have happened if he was sent non adjustable rocker arms.
SB is online now
Old 03-07-2024 | 04:26 PM
it'd be severely rpm limited.
sutphen 30 is offline
Old 03-07-2024 | 07:07 PM
SB
Lol
SB is online now
Old 03-08-2024 | 12:19 AM
Thanks for your comment and suggestion however I already bought the adjustable ones. I wouldn't have known that there was an alignment issue except I had a lifter fail. During that repair I posted a few pics of the collapsed lifter and several people here noticed that my rockers were not even close to being centered on the valve tip. Turns out the AFR 265cc heads require the adjustable guides and I was just wondering if the other manufacturers required them too. I think my builder should have called me during the assembly and told me he needed the adjustable ones. I think he would take care of me "labor wise" but I know the first sentence out of his mouth will be pull the engines and drop them off and that is not going to happen. So I'm going to find out just how much of a PIA this is to do.
Thanks again for your suggestion.
I looked back at your old thread about the lifter failure and you can see the adjustable guide plates in the pics. I didn't notice them back then when I commented about the rocker tip being way off. Lifter making noise - Offshoreonly.com
Griff is offline
