Adjustable push rod guides
Griff, since we're on the topic...just to clarify on the rocker alignment... narrower contact sweep roughly in the center is better than wider sweep that is perfectly centered?
This is also a factor of what can live on a street or perf engine vs sustained high rpm on a marine app.
ICDEDPPL (03-13-2024)
LOLOLOLOLMFAO!!!! danny, danny, danny. WTF are you doing posting on my thread?? You are obviously not here to help. Practicing your comedy act??? Based on the post, it needs a lot of work.
I've seen where swapping rockers from spot to spot can "fix" side-to-side alignment of the roller on the valve tip. I know it makes no sense. They should all be exactly the same, but my Comp Pro-Magnum full roller rockers were like that. Wouldn't have believed it if I hadn't seen it with my own eyeballs.
Hey danny, I stand corrected about your comedy. I see that 2 guys "liked" your comedic post however I have it from a very reliable anonymous source that they also like to get together and watch Pauly Shore movies because they think he is hilarious too soooo........
Lol!!! I will never give up his name especially not on this site. If you care to look on previous threads, only one person thought I would be okay with the builds "as is" and he was correct. To be fair to him, he too would not build any marine engine to the spec's of my engines. The rest of you acted like an old fashioned lynch mob. My guy doesn't build like ewe therefor lets put him out of business!! Had the same sh!t happen when I had a lifter problem. It was said that Comp makes the worse lifters out there, here are some "pics and everything" of failed comp lifters proving that they have an inferior product and obviously they too should be put out of business!! I countered those statements with very specific questions about their builds and all went silent. I do believe that the failed comp lifters they selected andused were never meant for their particular application whether it was a target rpm they wanted to run, valve spring pressure or I'm sure many other reasons that I have no idea about. This seems to me more like a failure on their part to select the correct part(s) for the application and not a comp lifter problem.
Ryanw, Unlike me, I,m sure you (or anyone else on this site) would ask or request your engine(s) be assembled using your known parameters. None of which I did and it should be noticed that in the face of almost everyone's opinion here, my "horrific builds" (as stated on another thread) ran strong and reliable all season long and I look forward to many years of great service from them. The lifter issue had absolutely nothing to do with my builder and you guys know that.
As another layer of defense from my builder, I mentioned he wasn't really a boat guy. The only reason he took my builds on was because during "the covid" no parts were available for all of the customer engines at his shop but I had been collecting my parts for over a year and had everything ready to go so again, really no reason for a name.
I know of plenty of builds that made it through a season or two and then had catastrophic failures deemed to have been caused by assembly and clearance issues after they were tore down.
When they make it past 250 hrs, and for your sake, I hope they do, I'll be a believer.
Thanks for your comment Griff . I was wondering if there was a "once you make it here you're probably safe" number. If there is a failure, I will not hesitate to post it here. Thanks again for your guidance and help along the way.
1) cut pushrod guide plate. Move 2 halves to where proper placement is, then weld 2 pieces together.
2) Buy/use adjustable guideplates
3) Do nothing. Your motor/you (or you and builders) decision.
Rocker stud bosses are rarely in same exact spot from head to head…even with same manufacturer.
1 and 3 where the common choices. 2 became a choice because they finally became available. 15 yrs ago or so ? 20 ?
They’ve been available for sbc’s since i can remember. Back to the flinstone ages.
