-   -   BBC 509cid tunnel ram efi build. (https://www.offshoreonly.com/forums/general-q/381984-bbc-509cid-tunnel-ram-efi-build.html)
JaniH 05-04-2024 02:48 PM
Should i use this type of seals on exhaust and intake?
https://www.summitracing.com/parts/cca-517-16
sutphen 30 05-04-2024 04:25 PM
does flotech give you the guides top cut dia. for the valve seals.viton is what you want.
JaniH 05-05-2024 02:31 AM
According flotek site, the valve guide OD is 0.500".
JaniH 05-05-2024 02:33 AM
Found these runner extensions for weiand tunnel ram. 2" and 4" available.
https://www.ebay.com/itm/23550828552...4AAOSw2GlXKNCR
Mbam 05-05-2024 08:47 AM
Back in the early 80's I had a pair of engines built by a big name guy near Detroit. Had those same intakes. Made good power but in order to lower the RPM band and increase torque he made some spacers like that. Worked great on the dyno. However first run out on the lake it broke one balancer clean off. On disassembly found the other one seconds away from the same fate.
Only thing we could figure was that the spacer really screwed up the air/fuel distribution.
articfriends 05-06-2024 09:33 AM
would be interesting to see on a dyno with 10 o2 sensors like mine has, I see some stuff thats almost unusable as far as afr delta!
JaniH 05-06-2024 01:28 PM
My plan is to make the first dyno pulls with headers and 8x02 sensors, and see what cylinders needs more fuel, and then change to my stainless marine manifolds and do the final tuning. My last engine Lost 19hp and over 40tq, with Sm (dry to transom risers) vs long tube headers.
https://cimg6.ibsrv.net/gimg/www.off...9878950615.jpg
https://cimg2.ibsrv.net/gimg/www.off...f8345f7cad.jpg
https://cimg3.ibsrv.net/gimg/www.off...b64f311792.jpg
JaniH 05-06-2024 01:55 PM
Some progres today, i set/cut angles for the injector bungs, still needs quite a bit welding but not bad.
https://cimg8.ibsrv.net/gimg/www.off...bee4b85016.jpg
https://cimg0.ibsrv.net/gimg/www.off...506bf23a22.jpg
https://cimg1.ibsrv.net/gimg/www.off...3b7b49390f.jpg
JaniH 05-09-2024 02:08 AM
Made a good deal of 8qt milodon full kick out pan. Dont know if it is any improvement over the merc original 8qt with scraper, but it looks cool.
https://cimg3.ibsrv.net/gimg/www.off...22fbe0a76d.jpg
https://cimg5.ibsrv.net/gimg/www.off...3014d761fd.jpg
JaniH 05-15-2024 03:35 PM
2 Attachment(s)
Heads are ready. ferrea 6000, int 30dg backcuts, new seats, bowl/short turn blend, good port had too high air speed @.600 and up, trimming the head bolt pump fixed the problem. 1=good port, 2=bad port, 3=exhaust no pipe, 4.5" bore adapter.
https://cimg2.ibsrv.net/gimg/www.off...85a78e85e8.png
