Prop Questions >
Prop Questions
Prop Questions
Old 12-03-2002 | 06:10 PM
BajaBennett's Avatar
Angry Prop Questions
I have a 302 Baja that I just repowered with stock 502 Mag MPI's. I have installed Stainless Marine exhaust straight through transom with Shotgun silencers. I also have installed Vortex flame arrestors. Bravo drives (1.5/1) turning Bravo I 26P, four blade stainless props, turning out. The boat is showing 68 MPH of GPS @ 4600 RPM's. The engines should turn up to 5000 RPM's.
I can have the props labed and pick up about 300 RPM's. Is this the best way to go??? What will I loose??? Any thoughts out there guys?
BajaBennett is offline
Old 12-03-2002 | 06:24 PM
Ric232
The only thing you'll lose is durability in the props. I don't know if you should expect to get 300rpm if you are sending the props to Mercury. You'll get it if you send them to Houston Propeller.
Your other options are 24P Bravo 1's, 23P Mirage Plus's or 23P Rev 4's (not sure if they come in LH rotation). If money is no object, I'd get the 24P Bravo's, do a baseline run, and then get the 24's blueprinted with some add'l cupping and/or pitch.
Old 12-03-2002 | 06:36 PM
liquid asset's Avatar
Labbed 25'' or 27'' mirage plus will be the fastest prop, the 4 blade is slower, however my buddy did get 300 rpm from mercury's lab process
liquid asset is offline
Old 12-03-2002 | 09:30 PM
HOUSTONPROP's Avatar
Default that's the ticket on bravo's
that exactly right If money is no object buy 24 bravos and have them customized. or we can try our best to de pitch the 26's to 24 and customize them to work good /let me know DARIN
HOUSTONPROP is offline
Bajapred
Prop Talk
4
02-12-2007 11:23 AM
Havasu Cig
Skater
11
05-12-2005 06:36 PM
HOUSTONPROP
American Offshore
3
11-15-2002 01:01 PM
