Merc Racing 500 EFI Error Code "General warning #1"?? >
Old 06-25-2024 | 10:38 AM
Revelocity's Avatar
Default Merc Racing 500 EFI Error Code "General warning #1"??
The Rinda tool reported "General warning #1 telltale has been set".
Does anyone know the likely source(s) of the General warning #1 or it's implications?
Thank you!
Revelocity is offline
Old 06-25-2024 | 01:31 PM
TomZ's Avatar
Check the drive lube.
Oil pressure good?
TomZ is offline
Old 06-26-2024 | 08:22 AM
Revelocity's Avatar
Both good - thanks.
Old 06-27-2024 | 02:22 PM
Been chasing the same issue. I assume your alarm is going off? Mine comes and goes sporadically. I started a thread on this and got some pretty good input on three inputs for the alarm...high coolant temp, low oil pressure, and drive lube monitor. Was told to disconnect them one by one and see if the alarm stops being triggered but thus far no change with the drive lube monitor so onto the other two sensors this weekend.
pq270jtw is offline
Old 06-28-2024 | 12:25 AM
Link to thread 500 EFI MEFI3 computer fault - Offshoreonly.com
Griff is offline
Old 06-28-2024 | 07:23 AM
Revelocity's Avatar
Thanks so much. Very good information!
