496HO T-stat >
496HO T-stat
496HO T-stat
Old 07-19-2024 | 05:27 AM
Originally Posted by Rookie
Put it back together with the 140°F that is recommended. I assume the Whipple thermostat is a high-flow version. Do not run the Amazon version and get the high-flow from CP Performance.
https://www.cpperformance.com/c-123-thermostats.aspx
Aside from the fact he likely needs a 140 and not the 160 on Amz.-
When you say Amazon version are you referring to the Stewart Warner High Flow I linked, this is actually a Robert Shaw T-stat marketed by SW? Just trying to determine if there is a functional difference or known quality issue with the Stewart Warner (Robert Shaw) T-stat. It is Brass construction. Do we know anything about who manufactures or where the CP T-stat comes from? As I am fresh water I see it as a one in maybe 10 year purchase. I ran my 120 High Flow (unknown brand, bought in 2001) for 10 or 12 years and it still worked same as new. I am just looking to source a 160 high flow for a different boat and or perhaps a 140 depending upon some further testing. Just easier to for me to buy from Amz, Prime, free shipping etc. I am going out on a limb I suspect any Brass one we come across is likely made in the same place.
Amazon Amazon
BadDog is offline
Old 07-19-2024 | 11:17 AM
Originally Posted by Don_Juan
Not to hi-jack this thread, but I never knew about the 1" plate. My Whipple 496 has a 120 tstat. During the middle of the summer, it runs about 145-150 degrees running. When I come into a 5 zone, it goes up to maybe 160. I have forged pistons. Any benefits to switching to a plate on my setup?
DonJuan,
I'm not the expert, and I have no empirical evidence, but here are my thoughts....
I guess it depends on whether you have closed cooling or not. From all the reading I can find and contemplating on it, this seems to make all the difference. If you have fresh water cooling, I can definitely see the need for a T-stat. You really don't want pockets of 85° water coursing through your block and heads. But with closed cooling, the coolant is going to warm up regardless, and it will not have the occasional pocket of much cooler water. It may take a bit longer to get to temp, but not significantly. The end result will be more cooling capacity via higher flow than a T-stat will allow.
We're gonna find out.
Thanks. Brad.
Brad Christy is offline
Old 07-19-2024 | 12:00 PM
@Brad. Yes, stock heat exchanger. 87Mirage thought my temps were good with the 120 tstat. But if a plate cools it down another 5-10 degrees, maybe I should try the plate. More flow seems better. As far as warm up, I have ten minutes in the 5 zone to fast water.
Don_Juan is offline
Old 07-21-2024 | 06:55 PM
Rookie's Avatar
The Amazon did not have the spring loaded bottom plate like the 496 does. I have no idea if necessary or not. I also run the SW High Flow T-stats with no issues.
Rookie is offline
Old 07-22-2024 | 09:19 AM
Rookie,
The one I linked is a Quicksilver, from the Quicksilver store. What's the difference between this one and what you're talking about?
Thanks. Brad.
Old 07-22-2024 | 09:23 AM
SB
UnderPSI,
For the record, “I” ain’t doin’ sh!t. But I’m guessing Hilltop will know to check all known culprits.
I’m getting good flow from the intercooler overboard, if that means anything. I also had a new water pump, including impeller, put in last spring, so I’d assume the impeller is good, but I did run it for an extended period on the hose during the oil temp gauge project. I’m sure Hilltop will check/replace that, too, while they’ve got me bent over the counter.
Thanks. Brad.
Never assume (guess) . Sincevyour going in for a cooling issue, Tell’m you want these replaced anyways. :thumbs
SB is offline
Old 07-22-2024 | 09:33 AM
SB,
Agreed, and that would be the plan. It's been the better part of two seasons, anyway, so no money lost/wasted. I am just trusting them to not let me forget.
Thanks. Brad.
Old 07-22-2024 | 10:17 AM
SB
My screen name is SB.
Most of us , but not all, choose not to use an actual name.
Thanks.
SB is offline
Old 07-22-2024 | 10:21 AM
Thanks.
SB,
Heard and corrected.
Apologies.
Thanks. Brad.
Old 07-22-2024 | 10:48 AM
Rookie's Avatar
Rookie,
Thanks. Brad.
Post #7 is the 496 thermostat.
Rookie is offline
