Surging 2001 Kohler 7.3e >
Old 07-19-2024 | 08:28 PM
Default Surging 2001 Kohler 7.3e
Need some help!
I have a 2001 Kohler 7.3e with 153 hours on it. It will start right up and run for hours, surging the whole time. I have changed the plugs, changed the oil and changed the external water/fuel separator. At some point (I am the third owner) they removed the in line Kohler fuel filter and replaced it with a spin on canister style water/fuel separator. I have run a can of marine grade Seafoam through it - no change. Short of replacing a carburetor that probably has varnish in it, do you have any other suggestions?
tmlawler@sbcglobal.net is offline
Old 07-20-2024 | 05:45 AM
There are lots of discussions about that generator engine over at thehulltruth.
Markus is offline
Old 07-20-2024 | 05:58 AM
How difficult to remove and clean the carb? Surging generally indicates lean condition caused by clogging of the smaller (low speed jets, passages) of the carb. It could also be a small vac leak or a plugged fuel supply vent. Most likely a simple RnR with a good cleaning will cure it.
Here is an article where someone had a problem with the electric choke-
https://theprojectboat.com/2021/08/1...the-nauti-oar/
Seems you could just hold the choke as a test or observe the relative position.
See 4.5.4
https://www.moreman.spb.ru/upload_fi...6_eng_gzrw.pdf
BadDog is offline
