Vibration Increases with RPM 454 Mag MPI based 468
The front of the intake plenum, and spark arrestor are both seriously rubbing on the fiberglass drip rail. That issue alone would cause even a smooth running engine to
sound like it is vibrating. I would suggest fixing that first before taking anything apart!
With Merctrans...assuming the block is a Mark IV 2 pcs rear main crank with the MPI added to the 9lder block?
Or one pc rear main crank Gen V or VI?
This seems.to be an issue from the the 1st time you saw it, and never.seen it smooth past 3000 rpm?
Maybe it has an internal balanced flywheel on it.
