Starter going bad?
Merc. 5.0L EFI. Eng. starts normally when cold. When warm after running the starter will engage, crank eng. for 1-2 sec's, disengage and wind down. If I keep bumping the start switch eventually it will crank long enough to start. Does this sound like a dead spot on the starter windings?
Does your boat have the remote solenoid? I had a voltage drop at the remote solenoid that gave me fits. Turns out I f'd up the wiring but the voltage drop kept the starter from engaging. You could hook up a remote starter switch and see if the starter works properly after it gets hot. That would probably be enough to tell you if it's the starter or something upstream.
