Camshaft Recommendations >
Old 10-20-2024 | 11:53 AM
See quote
jeffswav is offline
Old 10-20-2024 | 11:55 AM
See quote
jeffswav is offline
Old 10-20-2024 | 11:59 AM
Originally Posted by Smitty275
Chris Straub in East Tennessee is highly regarded by a lot of builders. I'll be getting my next one from him to try out.
Actually just talked to him on Friday. Said he could get me more torque and HP with better fuel economy. Recommended a cam that was actually smaller than what I expected.
jeffswav is offline
Old 10-20-2024 | 12:01 PM
Default Lunati has removed most of its BBC cams off the website. Not sure whats up with that.
Bullet cams is talked about here, personally Ive not used them, Lunati , TCM in Cali has some off the shelf cams but I dont think they grind them. I had cam motion do a custom grind for some 540's but that was 9 years a go
jeffswav is offline
Old 10-20-2024 | 12:45 PM
I had Chris to design a custom cam to my old engine, and highly recomend his custom cams! Hi knows how to get the most out of your not so good cylinder heads. My engine made 528 dyno prooven hp with ported peanut port heads.
JaniH is offline
Old 10-20-2024 | 12:47 PM
quited to wrong post, sorry.
JaniH is offline
Old 10-20-2024 | 12:51 PM
JaniH is offline
Old 10-20-2024 | 01:03 PM
I have AFR clone heads with AFR valves. I reused the cam on my last refresh that was setup for GM large ovals and lower compression. Shooting for 600+ HP
jeffswav is offline
Old 10-20-2024 | 06:05 PM
SB
Bullet/Comp/Teague, etc, etc
Straub was banned from this forum. For legit reasons.
Caveat Emptor.
SB is offline
Old 10-20-2024 | 11:05 PM
what were the cam specs on this magical engine,,I can compare it to my 524 and 527hp cast iron oval port headed 454's.
sutphen 30 is offline
