496HO Pops and Backfires
BBaker,
I'm no wizard, but I have had my fair share of experience with the 496HO.
Do you have a Rinda TechMate scan tool? You can use it to do a cylinder delete sequence for both injectors and ignition to help determine if you are actually missing cylinders and which ones. It sounds like just about everything else in is order, so I'd start there.
Thanks. Brad.
Thanks. Brad.
BBaker,
Yup. Mine ran on 6-1/2 for an entire season. I knew something was wrong, just from the lack of power. I just couldn’t figure out what it was. To listen to it, idle through “WOT”, I couldn’t really hear that it was running wrong.
Thanks. Brad.
Thanks. Brad.
Yes. You set the throttle at about 1500 RPM, in gear, and delete a cylinder, one then the next, and listen for a lack of a drop in engine RPM. That's a dead cylinder. Do this with both injectors and ignition, and you'll root out any issues with these systems.
If the engine just won't stay running at all, I'm not sure what to tell you other than to have the ECM tested. They DO go bad. I'd think this would throw a code, but I don't discount ANYTHING when it comes to electronics. A faulty component could also prevent it from throwing a code. Electronics are just voodoo. John Mosetti at Boats Unlimited can test and repair them. This is all assuming there isn't some other, simpler solution; Occam's Razor and all. You might also send the injectors to Smitty (ArcticFriends here on OSO) and have him test and/or clean your injectors. Wouldn't hurt to send them from both engines while you're at it. Eliminate this as a potential cause. It's not like you're going to be using the boat in the interim.
Thanks. Brad.
Thanks. Brad.
