Why is this plumbed this way? >
Old 01-05-2025 | 07:37 AM
Default Why is this plumbed this way?
I am working on getting this Superboat going. I have a really bad boat problem. When I bought the boat I new the engine had taken in water and needed to be replaced/rebuilt. The owner said the boat overheated and cut out. His mechanic said the engine overheated and caused the exhaust manifolds leaked water in. I am in the process of removing the engine now.
I have never seen water routed this way? I have always plumbed incoming water to a crossover in the block then the water circulates through the block to water outlet/thermostat housing and then to exhaust manifolds. As you can see in the photo incoming raw water goes to a "T" in the block which then goes to the water outlet? To me this wouldn't pass water through the block necessarily? All may be diverted to exhaust manifolds?
SkiDoc is offline
Old 01-07-2025 | 07:28 PM
TomZ's Avatar
Plumb it the way you think it should be done. That mess is much more complicated than it needs to be.
Thats my opinion.
TomZ is offline
Old 01-07-2025 | 07:37 PM
Whatever that puzzle is it appearantly didn`t work so well . I agree with Tom , rip it all out and start fresh
ICDEDPPL is online now
Old 01-08-2025 | 04:20 AM
Thanks guys not sure what was going on there. I will redo the tried and true way.
SkiDoc is offline
Old 01-08-2025 | 10:28 AM
I guess the water system did work. The cylinders got a lot of water.
SkiDoc is offline
Old 01-08-2025 | 11:50 AM
I didn't know marine engines were using water injection now too!
CheckmateScarab is offline
Old 01-08-2025 | 03:24 PM
TomZ's Avatar
Ouch!
TomZ is offline
Old 01-08-2025 | 03:51 PM
Gaskets installed upside down or wrong gasket?
boatnt is offline
Old 01-08-2025 | 06:31 PM
I don’t know that it was the head gasket? Do you see something?
On the forensic examination the raw water pump plastic body had a section missing so I think it overheated. Both banks had the same water in them so I don’t think it was an exhaust manifold because I don’t think 2 would fail at one time. I think water got sucked back into the engine from the exhaust. Flappers not working.
SkiDoc is offline
Old 01-08-2025 | 06:54 PM
jeff32's Avatar
ouch... serious mess here !
needs serious doctor to fix this ...
jeff32 is offline
