Promaxx Heads >
Promaxx Heads
Promaxx Heads
Old 10-19-2025 | 06:20 AM
  #71
Ppl
SkiDoc is offline
Old 10-19-2025 | 06:27 AM
  #72
Finally did dyno the engine. Thanks to Ray at R&R Motorsports. I will post the sheets. Ended up about 530 HP and lots of low RPM torque. I made the mistake of not buying a new carb and just using the old one so that compromised my ability to tune in the idle. I’m not sure anything significantly more going to happen on the big end.
i was really nervous this being my first build but it didn’t scatter and it looks like I built a good engine. No leaks. It went very well. I’ll post more data so that it can help others with their build choices.
SkiDoc is offline
Old 10-19-2025 | 06:36 AM
  #73
SB
1st time Being on the dyno can be nerve-racking for sure.
What did you find , and do, with the belt alignment ?
SB is offline
Old 10-19-2025 | 06:57 AM
  #74
Congrats on the build Doc. Looks like we share a few of the same parts. Promaxx heads, Canton oil pan, and MSD distributor.
What material are your freeze plugs? The one on the back of the block doesn't look to be brass.
SB, if you're asking about my belt alignment problem, there wasn't one. The problem was me. I was trying to use too long of a straight edge that was causing me issues. I bought a piece of straight 3/8" rod and placed it inside the pullies and everything lined right up. I then placed it flat against the back of the pullies and once again, everything was good. Chalk it up to user error.
There was no problem with the Promaxx heads and OEM accessories installation.
xlint89 is offline
Old 10-19-2025 | 10:42 AM
  #75
articfriends's Avatar
I've dynoed engines at my shop the first time for guys that have built engines for years but never dynoed and even most of them get a little nervous, smtty
articfriends is offline
Old 10-20-2025 | 01:58 PM
  #76
Jim Diesel's Avatar
"Unregistered Gun"
That's awesome, Ray is a great guy!! He built my blocks and assembled with the Promaxx heads that Saris Racing built for the project.
Jim Diesel is offline
Old 10-20-2025 | 07:38 PM
  #77
The silver steel block off plate is to seal off the rear of the cam tunnel. It sees only oil on the other side.
Tartilla is offline
Old 10-20-2025 | 09:16 PM
  #78
Did not know that. Thank you
xlint89 is offline
Old 10-22-2025 | 05:10 PM
  #79
Hey Skidoc, did you manage to get a copy of the dyno sheets?
Tartilla is offline
Old 10-23-2025 | 04:30 AM
  #80
This is a snap from video of the best pull with not my carb was the best Hp. Was a Willy’s carb. I will post sheet in a few when I get to office
SkiDoc is offline
