CoolFuel Module >
CoolFuel Module
CoolFuel Module
Old 02-04-2025 | 05:47 PM
Originally Posted by Griff
Merc does not sell just the pump any longer, so you have to buy the entire unit for about $900, but after market pumps and regulators are available for about $200.
https://www.mercruiserparts.com/866169t01-pump-kit-fuel
Edit: looks like this a gen 3 pump. Shouldn't the only difference be the electrical connector?
Ryanw10 is offline
Old 02-04-2025 | 11:34 PM
Completely different and won't match up to any of the Cool Fuel 2 connections
Griff is offline
Old 02-05-2025 | 08:28 AM
First off - thanks for posting this photo as I have to replace my high pressure pump and can barely see the thing...can reach but limited visability.
Second, I ordered a pump on amazon which the Merc Manual says is compatible.- hoping it is the right one.
Third - is the connection to the cool fuel tube just an O-ring?
Swamplizard is offline
Old 02-05-2025 | 11:51 PM
Yes, the small end just presses in place
Griff is offline
Old 02-06-2025 | 04:21 AM
Griff, Swamp,
Which connection are you referring to? The fuel output?
Thanks. Brad.
Brad Christy is offline
Old 02-06-2025 | 08:32 AM
yup. Pump is threaded on one end and not threaded on the other. Pushes into the cool fuel housing and I think it has an O-ring....but wont know until I take mine apart.
Old 02-06-2025 | 08:35 AM
Swamp,
Can you post a pic of the new pump you have? Maybe that will shed some light….?
Thanks. Brad.
Old 02-06-2025 | 08:39 PM
Griff, Swamp,
Thanks. Brad.
The end with the wires presses onto a nipple fitting with O rings Fuel Pump and Fuel Cooler
Griff is offline
