Kiekhaefer disassemble question >
Old 12-08-2002 | 07:20 AM
cig1988's Avatar
Default Kiekhaefer disassemble question
I'm in the process of removing the k-planes from the transom. Some of the pins are seized. I have tried soaking with wd-40 etc. Still no luck. A little reluctant with alot of force in fear of breaking the aluminum. Tried some heat, not budging. HELP!!!
cig1988 is offline
Old 12-08-2002 | 09:08 AM
formula31's Avatar
Common problem. Try some PB blast instead of the wd-40 before getting too violent. Mine came out with some pounding after I got them to rotate. Try doing a search. There were any other threads regarding this problem.
formula31 is offline
Old 12-08-2002 | 04:59 PM
cig1988's Avatar
I tried a search, could not find anything. I guess I'll try the pb blast. Heard about the stuff works wonders. Anybody else?
cig1988 is offline
Old 12-08-2002 | 05:02 PM
mcollinstn's Avatar
Whatever you soak them with, tap on them lightly a bunch of times (an air chisel on low works real good) to get the lube to creep thru the hole.
mcollinstn is offline
Old 12-08-2002 | 05:38 PM
cig1988's Avatar
Thanks Mac, I'll try that too.
cig1988 is offline
sleek1
Do It Yourself, Boating on a Budget
5
07-05-2008 04:07 PM
JETFIXR
3
06-16-2008 08:48 PM
JUSTONCE
9
03-04-2003 10:44 AM
Steve A.K.A RAMPAGE
1
02-27-2003 03:12 PM
Steve A.K.A RAMPAGE
1
08-30-2002 05:04 PM
