crappy crab style distributor cap >
Old 05-03-2025 | 05:07 PM
here you go
https://www.summitracing.com/parts/s...MaAkEzEALw_wcB
sutphen 30 is offline
Old 05-03-2025 | 05:41 PM
Originally Posted by sutphen 30
that looks like what I need but it did not come up when I looked at summit earlier because for some reason it is listed as small block only even though they are the same. didnt think to look under small block as you would think summit would have fixed their search engine by now.
thanks for finding it for me.
compedgemarine is offline
Old 05-04-2025 | 06:18 AM
lol...now I get the 'crab' reference!
Baja 252 Islander
bajaman is offline
Old 05-04-2025 | 07:47 AM
Veteran: Army
The NAPA Echlin RR207 is brass and has a good reputation.
DrFeelgood is offline
Old 05-06-2025 | 07:54 PM
[QUOTE=DrFeelgood;4925518]The NAPA Echlin RR207 is brass and has a good reputation.[/QUOTE
Looks like AL now
https://www.napaonline.com/en/p/ECHRR207
BadDog is offline
Old 05-06-2025 | 08:58 PM
Veteran: Navy
MSD 8017.. $87.99 ea. Cap with brass. Comes with rotor. You got about 2 years out of them.
AmiableDave is offline
Old 05-07-2025 | 07:19 AM
Veteran: Army
[QUOTE=BadDog;4925711]
Looks like AL now
That's disappointing. I bought one with brass terminals for ~$35-40 just about 2 years ago.
Old 05-07-2025 | 07:26 AM
Veteran: Army
FYI, here's an assortment of caps from RockAuto, some noted as having brass terminals. I'm not sure about the vented/non vented aspect, I suspect we're supposed to use non-vented to avoid igniting fuel vapors. The OE part from GM is D329A and it has aluminum terminals, FWIW.
https://www.rockauto.com/en/catalog/...butor+cap,7120
On the GM truck forums (Vortec 5.0, 5.7, and 7.4 all use these crab caps), the United Motor Parts version gets good reviews.
Old 05-07-2025 | 07:58 AM
I ordered the one from summit with brass and a vent. it is going in my truck so no problem with the vent. the one I ordered says 5.0 and 5.7 and has good reviews. oddly enough they list a separate one for the 7.4 (what I have) that is a different part number and does not have the best reviews. we will see how it goes. my thinking is the aluminum ones burn the surface of the aluminum after they run and starts the corrosion and since I dont drive it a lot that corrosion builds up instead of burning off and creates the misfire, or at least makes it worse. time will tell.
Old 05-07-2025 | 08:23 AM
SB
R
e
d
u
c
e
t
h
e
g
a
p
.035-.040” good.
.060” sucks and causes many issues
SB is offline
